Question about Panasonic Office Equipment & Supplies
How do i reset the daisy wheel on the Panasonic KX-R330
3 Suggested Answers
6ya staff
SOURCE:
Dick O Reilly
  • 3594 Answers
SOURCE: MY PANASONIC TYPEWRIITER KX-E7000 WONT
If it types something in place of the letter you need a printwheel, if it dosent do anything (print or space) the key board is the problem.
DickyO
Posted on Sep 23, 2010
Dean
  • 25 Answers
SOURCE: reset code for daisy wheel
I've found a manual that will be useful for your problem, you can find it here - Brother GX-6750 manual
Posted on Nov 15, 2013
Olivetti PT 505 types the letter pi when small caps m is selected. How do you reset this
If you are using a daisy wheel it will be an International daisy wheel or,check settings to see if it is set at International settings.If it is an international daisy wheel or a PS wheel change them for a standard 10" or 12"
May 10, 2014 | Office Equipment & Supplies
I have a panasonic electric typewriter R330 and it only types about in inch then stops how can i fix it?
The right margin is probably set. Hit margin release( MR) and see if it types, if so reset your right margin. Also something could me binding or caught in the path. maybe a correction ribbon or something is blocking it.
May 30, 2012 | Panasonic Refurbished Kx-r330 Typewriter...
How do i set a new daisy wheel for the ML 100
1. Open the top cover.
2. Pull the lever towards you to release the daisy wheel lock.
3. Remove the cassette daisy wheel by pulling it out of the machine by the protruding "ear' on the top right.
4. Insert the desired cassette daisy wheel into the slot and press down gently.
5. Slide the lever back to its' original position to lock the cassette daisy wheel in place. Make sure to press the lever firmly.
6. Close the top cover.
7. Press [CODE]+[RESET] to move the carrier to the previous position.
(make sure the daisy wheel cassette is not inserted backwards. The "ear" should always be on the upper right.
improper insertion of the daisy wheel may cause malfunction and incorrect printing.
It is not necessary to remove the cassette ribbon when replacing the daisy wheel.
Please check the shape of your daisy wheel cassette before replacing the daisy wheel. The daisy wheel cassette type "B" cannot be used with this machine.)
Dec 22, 2010 | Brother ML-100 Typewriter
MY PANASONIC TYPEWRIITER KX-E7000 WONT TYPE M'S OR 9'S SOMETIMES .DO YOU THINK I NEED A NEW DAISY WHEEL
DickyO
Sep 22, 2010 | Office Equipment & Supplies
When typing with my brother gx-6750 it types weird lingo is the type set messed up or can I reset them?
Your daisy wheel letters are bended not straight.
Switchoff just remove your daisy wheel & remove the daisy wheel from its cover & see all the letters should be straight.If any of them is bended jst make them straight by your fingers dont press too hard & then fix the daisy wheel back & switch on typewriter.
Jul 20, 2010 | Brother ML-100 Typewriter
How do I reset the Daisy wheel?
Turn the typewriter off. There is a release lever for the daisy wheel. it will rock backwards. take out the daisy wheel. Turn on the unit..the daisy wheel motor spins to the home position. inset the daisy wheel carrier, snap the carrier closed. You should be in home position. if not turn it offf and on again, the daisy wheel should spin. if not do the proceedure over again.
Happy typing
Dec 18, 2009 | Brother GX-6750 Typewriter
How do I replace the daisy wheel on my Brother GX6750 ?
There's a small handle a little towards the right of the print head. Pull it towards you to free the Daisy wheel, lift the daisy wheel up and drop in a new one. Always power off before you do this or you have to reset .
Dec 12, 2009 | Brother GX-6750 Typewriter
My typewriter (Brother GX-6750) does not print correct letters
look for bent or broken spokes on daisy wheel .turning unit off for 20 seconds and back on should reset the daisy wheel home position. probably the daisy wheel.
Oct 26, 2009 | Brother ML-100 Typewriter
The keys will not type the letters they are labeled with.
Do you have the daisy wheel cartridge inserted correctly? The "ear" on the daisy wheel cartridge should always be on the upper right.
If that doesn't fix it .....Try doing a daisy wheel reset by Pressing [CODE] + [RESET]. This will properly index the daisy wheel.
Mar 25, 2009 | Brother SX-4000 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
141 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
