Televison & Video Logo
Myk Myk555 Posted on Oct 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung un32eh5000 tv dark spots and very fussy picture
Un32eh5000 samsung tv led right upper and left lower corners have black spots. Center has none but whole picture is fussy?. TV was on when tornado took out power pole and transformer. The dvr and cable modem where both trashed. t-con board?
Sp Gupta
Level 3:
  • Samsung Master 727 Answers
  • Posted on Oct 15, 2017
Sp Gupta
Samsung Master
Level 3:
Answers
727
Questions
5
Helped
144531
Points
3137
Certainly not the TCON board.
3 Related Answers
gopakumarg43
  • 76851 Answers
  • Posted on May 23, 2012
SOURCE: Samsung UN32EH5000 32-Inch 1080p 60 Hz LED HDTV
Refer its user manual for more details. To download it, click here.
James Miller
  • 2226 Answers
  • Posted on Jun 02, 2014
SOURCE: I need Samsung Led TV UN32EH5000 firmware for asia pacific
http://www.samsung.com/us/support/owners/product/UN32EH5000FXZA
gopakumarg43
  • 76851 Answers
  • Posted on Sep 17, 2016
SOURCE: I have a Polaroid TV FLM-373B it was dead replaced the power board now I have picture and sound. But I still have a dark spot center lower screen. Is this a T-con board problem??
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
1helpful
Samsung UN32EH5000 - No backlights, replaced power supply, still no backlights
It seems like the main board is not turning the back light circuitry on.
Check the Back Light On/Off at CN803 pin/wire 6 you should measure 0V - 4.9V with 5Sec Delay.
Let me know if you require further assistance.
1helpful
Samsung led TV un60es8000 dark blotchy area on the upper right of screen. Most noticeable on greys,blues and blacks. The picture attached is the color most responsive to this issue (dark grey). Lighter...
This is caused by one of two things; a bad LED grouping (most common cause) either because the LEDs are bad or the power distributor fuse is blown and the group isn't getting power from the power supply unit. Or two: bad pixel group. But I'd check your backlight power supply for bad connections, blown fuses, or check your led groups for bad leds.
I wa watching and all of the sudden it blew off
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
