Question about Ovens
Timer stuck on auto, wont reset using reset button therefore oven won't turn on. Have turned off and on at ring main but no change as well as reset button. Any other ideas?
Sorry forgot make and model NEW WORLD g90M
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 121 Answers
Replace the timer
Posted on Oct 11, 2017
6ya staff
SOURCE:
Anonymous
  • 75 Answers
SOURCE: Auto Timer
hi there switch your oven off at the mains switch for one minute thenswitch back on and set the time this will disable the auto on the timer.
Posted on Dec 09, 2007
claire238
  • 4 Answers
SOURCE: Main oven won't turn on
I'm figuring you've probably resolved this, since you posted in November (and I've just joined the site today). However, I thought I'd post a solution just in case anyone else surfs in and finds the same problem.
We have the same sort of oven. After the power has been off, the oven won't work until you set the time on the clock. I think it's because of all the automatic timer features.
On ours, you have to press the two buttons with arrows on at the same time as turning the clock dial to change the time.
Good luck.
Posted on Jan 07, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: creda concept solar plus oven timer
Hold down the 2 left buttons together, and press the + or - button at the same time..
This should reset the timer.
Please leave a fixya rating for my solution.
Thanks.
Posted on Feb 12, 2009
Anonymous
SOURCE: Baumatic Oven - Setting the Clock/timer after power has been off.
Hi, You press the second and third button in together, hold them in and use the + or - buttons to set the time.
Posted on Jan 03, 2010
deandesley1
SOURCE: Kleenmaid Scala Oven. My oven will not turn on.
I had exactly the same problem. I followed the directions to reset the clock. That is the cooking button and finish cooking button. They look like a caserole dish and a casserole dish with a cross through it. Hold them down at the same time and the + and - button to advance the time. Be aware I had to try this a few times before it worked. Hope this helps, Dean
Posted on May 14, 2010
The ignition continues after gas lights on new world elegance/cooker and grill
The igniter will glow orange while the oven is on. This is NORMAL. If it went out the burner would not come back on when the thermostat calls for heat .
Aug 18, 2014 | New World G90m Gas Double Oven
Finding the model number
IF YOU STILL HAVE OWNER'S MANUAL IT WILL HAVE MODEL NUMBER ON IT
Nov 29, 2013 | New World G90m Gas Double Oven
Worn off cooker symbols
Contact manufactures website to request new labels.
Aug 14, 2013 | New World G90m Gas Double Oven
Where can I download a manual for a G90m oven
try to search them Google search engine...it will direct you a suitable site which contain your need.
Sep 02, 2012 | New World G90m Gas Double Oven
New World G90m grill turns off - overheating?
Its a good chance its the thermal control board to the fan (PCB),if faulty it doesnt allow fan to reach correct speed thus overheating.
Hope this helps
Feb 05, 2012 | New World G90m Gas Double Oven
G90m
no not the thermocouple it would not light if it was that , sounds like its the thermostat which should be in the makes hand book underspares .
Jan 06, 2012 | New World G90m Gas Double Oven
Grill ignition spark persists when oven on ! how to remidy the problem ?
New electrode or a short on the spark box or electrode out of postion
Oct 31, 2011 | New World G90m Gas Double Oven
How to repair hinges on new world oven
Usually doors lift off. You may have to dismantle the door to remove the hinges. Take one to a supplier to get the right hinge.
Jan 03, 2011 | New World G90m Gas Double Oven
New World G90M
Normally they are held on with metal clips at each corner, just pull the seal back and unhook the clips to remove the seal..
Re fit by hooking the clips into the holes in the front of the oven, you will probably have to stretch the seal to get it to fit with it being new.
Plz rate this solution.
Thanks.
Dec 19, 2008 | New World G90m Gas Double Oven
Fan does not always start immediately
The fan motor bearings have probably dryed out with heat of the oven, if you remove the fan blade you can spray it with lubricant, this will probably solve the problem short term, but eventually you will have to replace the fan motor.
Nov 27, 2008 | New World G90m Gas Double Oven
Ovens Logo
217 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
