SOURCE: HObart MOdel 1712 Slicer Sharpener
The tw sharpener stones should be fixed with the screw provided to the blade
SOURCE: Hobart AM 14 model pressure rise
Are you refering to the water pressure gauge near the top of the unit?
If so, during the final rinse/sanitize cycle the gauge should read between 15 and 25 psi.( flow pressure ) and is usually controlled by a water pressure regulator piped into your plumbing near the machine. Once the cycle has finished, it's normal to see the gauge register much higher pressure readings ( static pressure ) This is the water pressure being supplied to your building. Pressures of 60psi+ are not uncommon. What, I think, you're describing is normal.
All the best.
SOURCE: I am looking for a Hobart lower wash and rince
Part numbers are available at www.hobartservice.com
Click "Parts" on the left side of the page.
Click "Hobart SmartParts System" on the next page.
Answer questions to access parts breakdown and part numbers for your machine.
