SOURCE: Memorex digital CD alarm Clock Model MC7101
Hi - You can download the manual from the link below:
MC7101
Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: auto-set clock radio with digital
Hi masbarn - I could try and walk you through it but I've always believed it's better if someone has the manual with the pictures. The link below is for the T311. It supposedly is the same manual you need. If not let me know. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Jeff
SOURCE: TIMEX MODEL MF13/P8
Press all the four buttons simultaneously your digital clock gets resetted. It worked for me try it out.
SOURCE: Can't disable alarm feature on colock radio
Just press "Cancel" once and then press the "Wake Mode" button until the selector light cycles through the the music or tone modes...and then disappears.
THE WATCH IS SET OUT AS TOP LEFT BUTTON = B
BOTTOM LEFT BUTTON = A
TOP RIGHT BUTTON = C
BOTTOM RIGHT BUTTON = D
10 Half Digit Digital FL145, FL186
Normal Time Display
1. Press A to change mode.
2. Press B for EL.
3. Press C to toggle 12/24 hour format.
4. Press D to stop alarm sound.
Time/Calendar Setting
1. From normal time display, press A three times to enter setting mode. Seconds will begin flashing.
2. Press C to reset seconds to zero.
3. Press D to set and advance to next setting value.
4. Press C to increase digit; press and hold C for fast advance. Press D to set each setting value.
5. Setting sequence is: seconds, hour, minutes, month, date, day of week.
6. Press A to exit setting mode.
Alarm Setting
1. Press A to change to alarm mode (AL).
2. Press and hold C for alarm sound testing.
3. Press C to toggle alarm/chime on/off.
4. Press D to enter setting mode; hour will begin flashing.
5. Press C to advance digit; press and hold C for fast advance.
6. Press D to set hour and minutes.
7. Setting will automatically exit setting mode mode after minutes are set.
Chronograph Mode
1. Press A to change to chronograph mode (ST).
2. Press C to start/stop chronograph.
3. Press D to reset chronograph when it is not running.
Split Time
1. Press D while the chronograph is running.
2. Press D again to return to the chronograph.
3. Press C to finalize timing.
4. Press D to reset to zero.
