Question about Samsung Televison & Video
Samsung LED Un55hu8700fxza lost the picture image, but still has sound and the backlight with blue screen. What should I troubleshoot?
My 3yr old Samsung LED Un55hu8700fxza lost the picture image, but still has sound and the backlight with blue screen . I've changed the T-Con board but nothing changed. Can you help with isolating the problem; I can't imagine this is a new problem with Samsung after find this issue all over the web. What else can I do on my own? Thanks, Bill
I have a 32" Samsung LED TV with not picture. Audio is working.
Do flashlight test - if you can see image you need t con board. If no images seen, inverter board. TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 18, 2017 | Samsung Televison & Video
I have a Samsung 40" LED tv that has sound but no picture. You can see an image if you shine a flashlight on the screen. I see no backlights when I take off the back.
Hi!
Check the backlight circuit, but first, check the power supply of the blacklight circuit, does it feed the backlight circuit or not. If not, it's the power supply circuit, if yes, check the backlight circuit itself, and if it works, check the backlight themselves, the led. Good luck,
Serge.
Nov 01, 2016 | Samsung Televison & Video
Samsung series 5. 5500 LED TV BLACK SCREEN
perhaps the backlight invertor driver circuit.
Samsung TV Repair Part Number Identification Backlight Inverters LED...
See where the wires from the long LED strips on the both sides of the screen lead you to.
does your model have separate board for backlight ? or is it integrated with TCON ?
Aug 17, 2016 | Samsung 32" Class 1080p 60Hz LED HDTV -...
My samsung ln46c630k1fxza 46 inch t v that has no picture or backlights, i replaced the t-con board, that didnt fix the problem. can you tell me how to fix the problem?
Samsung LED TV Model UN46D6400UFxza has sound but ...
? 2:16
https://www.youtube.com/watch?v=s2hLKzdyDWU
Oct 21, 2013 - Uploaded by Clif Venom
Samsung LED TV Model UN46D6400UFxza has sound but no picture ... LCD & LED TV Repair - No Image ...Missing: ln46c630k1fxza
Samsung LCD TV screen went black (audio on, no picture)
Dec 20, 2015 | Samsung Televison & Video
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
I have a Samsung 60" LED TV. Everything work except I have no picture. I have sound and a backlight on the screen. I can change sources but do not see any images. I think that the T-CON board is bad.
You only have 3 modules in the back of that unit, the wifi and the sound master board and the video board. Samsung knows they have a issue with some, there is a diagnostic mode that will help you to determine, I would contact tech support before I bought a 350.00 module just to confirm, however I think your on the right track
Jan 07, 2015 | Samsung Televison & Video
No picture on mu LG television.
Try the old flashlight test, turn off the lights in the room. Turn on the set and flash a bright flashlight on the screen. Do you see the image or is the screen totally black?? If you see the image, then most likely you have a backlight problem. Verify that you have 24V on the power supply for the inverter
May 20, 2012 | LG 19LH2000 19 in. TV
Televison & Video Logo
121 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
