SOURCE: How do you uninstall Chromebook updates?
you could look at the uninstall programs in control panel to see if any chromebook updates are there for uninstall Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error. 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. hope it helps
or use the system restore to restore your computer to a time before the updates where installed or another time
You can use the System Configuration utility to perform a system restore. There are three possible restore points: System checkpoints that Windows schedules
To perform a system restore, follow these steps:
