SOURCE: AEG Dishwasher FAVORIT 3A Error Message C3
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
SOURCE: Electronic controls don't count down properly
Your problem is the electronic control board and unfortant that you cant repair or even get parts for it . Only if you get the whole control board will you fix your problem assy unless you find a good appliance man that repairs electronic control boards
you have to replaced the main control resoldering wont fix it because the relay itself has gone bad replacing the board will solve the problem
SOURCE: dishwasher keeps displaying c3
system.
If problem still persists, let me know.
Thanks for using "Fixya".
SOURCE: my bosch dishwasher won't drain
mine is doing this too. I am trying to figure out if its the pump.
Have you tried canceling the cycle? To cancel, turn the on/off switch to on, then press and hold for three seconds the two buttons labeled "Cancel Drain". Keep the door closed for the next minute so that the dishwasher can complete the cycle. During this time the pump will remove any water from the washer. Also you will notice that Bosch dishwashers always leave a little water in the system to keep the seals from drying out and going bad.
Hope this helps
Great Help
I have changed the front face plate pannel with the buttons, and got the error C3 Code.
You have to be careful when you install the buttons.
They require Alphabetical installation, check the back of the button and the panel itself.
Poor instruction from the supplier of the parts.
I have saved the $450.00 bucks L.O.L.
THANK YOU
THANK YOU, This was exactly my problem and solution. When I reopened the panel the buttons were out of alphabetical order. Once I corrected this the C3 error code was gone.
I had the same problem, and it came to be that the buttons were in a certain sequence. I put them in order and it works fine.
Thankyou Zoran
