GE Spacemaker JVM1640SJ Microwave Oven Logo
Posted on Nov 22, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore Microwave model 721 62624200
The two light bulbs that serve as a light and night light have blown on my Kenmore over the range microwave (model #721 62624200). I have the replacemant bulbs from Sears, but when I install them they stay on in the night light settinging and I am unable to put them on high or turn them off. Any idea why this is?
Thank you.
  • 3 more comments
  • Anonymous Oct 16, 2008
    Different model number (721 80593402), same problem. Sears came out for a very high price and said I might as well buy a new microwave by the time they charged me for a replacement motherboard and labor. The microwave was only one year old when the problem began.
  • Anonymous Mar 17, 2014
    where is fuse located on kenmore model 721 microwave
  • Anonymous Mar 19, 2014
    the oven turns on sounds like its working but it does not heat anything
    Light doesn't come on?
  • Anonymous Mar 24, 2014
    it stays on when you open the door
William Miller
Level 3:
  • GE Master 9,179 Answers
  • Posted on Nov 26, 2007
William Miller
GE Master
Level 3:
Answers
9179
Questions
Helped
4478326
Points
21747
We see this a lot. The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 15, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4044
Points
I have a problem with the light bulb. It does not stay on when I set the time for heating or cooking. I changed the bulb with no sucsess. Kenmore model 721 serial # 301km02320
Anonymous
Level 3:
  • Master 473 Answers
  • Posted on Nov 23, 2007
Anonymous
Master
Level 3:
Answers
473
Questions
Helped
451816
Points
1483
On this one, the lights are controlled directly from the mother board. If they can't be shut off then the problem is in the board and will need to be replaced. The control board assembly costs $115.49 and part # is 4781W1M307C. You can get it at http://www3.sears.com/.
1helpful
Kenmore microwave nights light don't work.
That's a problem on the circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
I replaced the outside/night lights on my Kenmore microwave and the lights stay on. They are 3 settings, high, night and off and they do not cycle through, they are always on and won't shut off
This is a shorted relay on the control circuit board, which we normally repair for $39.95 nationwide.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
3helpful
Although I have changed the light bulbs, the lights that illuminate under the microwave onto the stove top will not work. This is a Kenmore over the stove Microwave Oven Model 721.80592402. Have their...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year guarantee.
Kenmore micro model 721
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
1helpful
Covers over cooking/night lights are melting
I have a microwave above my stove also but it has not done what yours is doing. I would try a lower watt bulb since it would not give off as much heat. You may need to replace the lens or else just take it out and get rid of the problem altogether. You would have a brighter light anywas even if you kept the same bulb. Most of those bulbs are florescent and do not put out much heat anyway and seldom cause heat problems, esp. giving off enough heat to melt something.
1helpful
Kenmore microwave model 721.62644200
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
3answers
Kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
