SOURCE: Adidas watch
hold right side buttons . time will flash set using top button, then use lower button to move through each aspect of menu. You use the top button to make changes then bottom to go to next option. Lower left button to exit
Hope it helps
Roty:)
SOURCE: start buttons don't work after battery change Adidas Sports Timer
You will have to open your
watch, because the contacts or contact springs are not stiff enough,
so, you need to make them stiffer.
Do as follows:
1) Open your watch caseback
2) Extract the movement (carefully and using tweezers), do not touch dial with fingers,
3)Take
small brush and lighter fluid (ZIPPO) and clean all pushbuttons in case
from inside and out pushing them rapidly, then use dust blower to dry
the fluid out,
4)On the movement you will see contacts corresponding
to each pushbutton on the case. Use needle or sharp metal pin to clean
(scrape) off any visible residue from these contacts till they are
shiny.
5)Pull all contacts on movement sligtly outwards using tweezers but be careful not to brake. This will make them stiffer.
6)Reassemble the watch and the problem should be sorted.
Do not forget to rate, please.
SOURCE: I dont know how to change the date/time for my adidas watch.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ADIDAS watch manuals. Rate me, please .
SOURCE: Annoying Beep on Adidas Watch
On mine, when it shows the TIME menu, you press both right side buttons together. The KET sign disappears off my screen and it stops beeping everytime I press a button
Hi John Nice, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Does back of watch have 6 or so small notches around the perimeter or no notches?
