SOURCE: I need a Casio LK-30 AC Adapter
Check out this link:
http://www.zzounds.com/item--CASAD5
It looks like the right one to me. I am ordering one today for our keyboard.
SOURCE: Casio LK 200 and smf software
If you have the smart card slot you can save your songs to the memory card by using Anvil Studio which is a free program. Save your midi song in Format 0 and be sure to use channel 4 for right hand playing and channel 3 for left hand. Be sure to keep the file size under 80k if you have other channels active for other instruments!
SOURCE: Need replacement key set for Casio LK-110
You would need to call casio for such parts or go to a part store which by googling it you can find the parts for this unit.
SOURCE: My Clavinova CVP 305 Piano will no longer play the
The EPROM IC might be defective and might need a change but with the help of the Yamaha service.
Howeverr leave the set ON ffor several hours if you have not used or sparingly used.Sometimes moisture within the set can cause these issues which ccan clear up when the capacitors charge up or the board warms up.The interface is having some errors /conflicts that cause this conectivity.
So keep playing , do not switch off .
Hope this tip helps.
SOURCE: Does the Casio LK-30 keyboard
No it does not have a sustain pedal input an there is no way to add one, sorry.
