SOURCE: which string used for epiphone gibson lea paul special II guitar
This is really a personal choice as long as the strings are made for an electric guitar there are hundreds of different kinds, it mostly has to do with the thickness of the strings and how the thinner the string the easier it is to manulipulate, you should go to a good music store and tell them what type of music you play and they will give you some choices.
SOURCE: Epiphone Sheaton II guitar setup
This will help for starters:http://www.epiphone.com/images/EpiOwnrsManul.pdf This site has good info in the discussion:http://www.thefret.net/showthread.php?t=4728 There's info here too:http://epi.p3net.net/bbs/index.php.
SOURCE: Epiphone BB King Lucille guitar treble pickup in mono mode
Realize that when you plug into the one jack it disconnects the fingerboard pickup from the mix.
DO NOT USE "stereo" cables as it is intended to use TWO MONO cables, one for each side of the stereo.
IF you plug into the one jack that will connect to the bridge pickup, it will disconnect the fingerboard pickup from the mix BUT leave the fingerboard on its own jack.
That same jack will have BOTH fingerboard and bridge pickups IF the second jack (bridge) is not plugged into.
This is according to the schematic. If you find that yours works backwards, then either the schematic is wrong OR your guitar pickups may be electrically swapped.
SOURCE: I am trying to determine the year of my gibson
Try the Epiphone site:http://home.provide.net/~cfh/epiphone.html or maybe here:http://www.fretnotguitarrepair.com/links_history.htm You might also look here:http://www.jedistar.com/jedistar_vintage_guitar_dating_gibson.htm I hope one of these helps.
SOURCE: i have an epiphone korina explorer bass guitar,
They've been listed as cheap as $399.00 new:http://www.google.com/products/catalog?oe=UTF-8&gfns=1&q=epiphone+korina+explorer+bass+guitar&um=1&ie=UTF-8&cid=11627556200103526247&ei=iI0BTbViiqOdB4TvmOUN&sa=X&oi=product_catalog_result&ct=result&resnum=4&ved=0CDkQ8wIwAw# Depending on how much wear and tear etc. the value could be 60% of that. Here is another source:http://www.usedprice.com/items/guitars-musical-instruments/all/bass-guitar/
