no country told and service is by country. as are parts.
call them and ask for service.
the manual for this device has page and end of book called
who to contact for service.
RTM?
read it yet
buy the service manual (users guide does not cover error codes)
or call for help, Ricoh.
This error is for a blocked magenta print head, so if you have done it allready, run the printer headcleaning routine, this is normaly found in the print driver under maintanance, or in the seperate software if supplyed
1) This type of error in the Ricoh printer appears when the printer and the computer's connected network does not match.
2) When the printer is connected to that network, ensure that the connection of your printer is done and you can do the necessary changes and bring back the connection back to the computer.
3) Check the network ID of the printer to ensure that the computer and printer are connected to the same network.
4) The wireless lights on the printers control panel is an indication that the wireless network connection is established.
Did not report a solution, but quoting from link above:
Ricoh Sg 3110sfnw showing SC28211 error code
Ricoh sg3110 sfnw showing sc28211 error code.
In trying to Execute carriage change sp mode (3-009-002), I cannot find 'Engine setting' (which according to the service manual) supposed to be under 'Printer setting' menu from Service mode.
Can someone help on step-by-step procedure of getting to the "Engine Setting" (sp mode) menu please in case am omitting something along the line or is their a permission required?
28113 - Ink supply timeout error (Tank 3 error)
• ink supply pump error
• air sensor error
• The tank feeler is malfunctioning.
• ink level senor error
• The ink supply pump is faulty.
• The carriage is faulty.
• The ink level sensor is faulty.
• The CTL board is faulty.
• Turn the main power switch off and then back on.
• Replace the ink supply unit.
• Replace the carriage unit.
• Replace the air purge detection switch.
• Replace the CTL board.
