SOURCE: bof error hobart amx
Sorry so late for the reply.Im a hobart tech and i dont recall this model of your unit,are you sure the model isnt a am-14 or am-15?
SOURCE: hobart amx/aux-s dishwasher "bof" error code
press the 1st and third buttons on the display nxt to the start button then press the start button,this will change the the display to something like BOF1 then allow the achine to fill the rinse tank you will know when this has happened as the display will go out (all of it) then you can turn on the machine using the button marked with a I the start button will light red allow it to go green and you are ready to go ... if when you are boffing it it changes to FIL the your water pressure is to low good luc fella
SOURCE: looking for a hobart amx dishwasher wiring diagram
sr. we are using Hobart dish /w but not working this properly .when i start d/w display red light coming but not green light also heater working water coming can you help me
only a suggestion is it heating up what i remember it want move on until it heats up to it's working temperature, good luck
