Running on windows 7
No PC stated, just HP and win7.
wow.
that means we cant guess when PC was made, can we.
but the F11 key is the fix.
all 2006 and newer PC, from HP have F11 key.
see?
the magic recovery key.
you press power and hammer F11 , read your sevice guide yet?
its all there free to read at any time.
the the recovery screen pops, and you pick
repair startup fails. or restore
if either tell you the HDD is dead, it is.
there are 2 causes for w7 to fail to boot
1: hdd bad. (or sick, some are good bad or damaged (hard damage)
2: the OS is corrupted,
easy no just 2 causes, (I can list more, but I fixed every class failure of computers, for decades., 3rd cause is a bad PSU, low voltages
or NOISE from it. or bad memory, (all mobo issues,)
but in simple form , just 2 above.
its a serial process diagnosis. F11 is JUST step 1.
if PC was slammed the original OS is now gone and the original recovery features are erased the cure is totally different,. now.
RTM yet>
i cant direct you to your manual , you never told what PC you own.
oops.
http://www.pcdied.com/slammed.html
here is the offical site. we are not hp here, but here they are.
oops x2 , hp is down now.
https://support.hp.com/us-en/
read your service tag, on that tag is a full model name.
like DV6-1234us.
type in your model and find your page.
then read the service manual
look for F10 or F11 via search, and IT'S ALL THERE< in print.
SOURCE: Stop 7
I know Ricoh hasn't been supporting these for some time now. Do you have a set of drivers for this device?
SOURCE: The laptop doesn't boot up always.
I would try the following:
1. Remove the battery completely. If the computer boots properly several times in a row, then the battery may be causing the power supply to do strange things.
2. If you have experience removing laptop components, try removing the hard drive. Because you say the screen goes black (I assume the system powers off) sometimes after the HP logo, I doubt its Windows or a software issue.
3. If HP has a diagnostic CD you can boot to, try that.
4. It may be the power supply acting up. If it charges the battery, and if you can boot to Windows with the battery, try getting a new power supply.
5. Otherwise, it may be the motherboard of the laptop.
SOURCE: Dell dimension E310 wont boot
Go in bios and change the SATA mode to IDE or compaitibilty then check whether it is working or not
SOURCE: HP Pavilion dv6000 Black Screen!
If you see same picture on on external display, then its a bad news - faulty motherboard.
Try to contact HP, maybe they will fix your laptop. Look here
SOURCE: unmountable boot volume
hi,
-this can be a hardware problem or a software problem
-run diagnostics first on the computer
-turn off computer; while the computer is off, press and hold the "Fn" key then press power at the same time to initialize the test
-if you find error message like 0142 - this is a hard drive failure; contact your manufacturer for replacing your hard drive
-if no error is found, it is a corrupted Windows; you need to reinstall Windows, ensure you consult local technician to back-up files before installation.
cheers!
