Says network disconnected...signal strength very good with internet
I used Amazon's instructions and they worked great for me. Here's where you can find them:
Set Up Fire TV Stick
SOURCE: Internet Explorer cannot display the web page
try to use the internet tools option and delete cookies, delete files and clear history then close the internet explorer and try to open it again. Good luck!!
I am having this issue. One laptop works the other not so much. I cant use IE. I can use and run AIM and Windows Messenger. CANNOT do anything else. Did all the ip renew release and all that ****. cant figure it out... Have an excelent conection but IE wont do its thing... [email protected]
I've been having the same problem after I change my Aztech router to D-Link. I hope these can help you because my problem solved after doing it.
Go to Control Panel > Internet Options > Connections > LAN Settings and make sure you check the 'Automatically detect settings' option box and the other two boxes is left unchecked. Good luck!!!
SOURCE: computer and wireless router being connected but no internet
To reset the Modem all you have to do is to get a Paper Clip or any object that is like a paper clip then just turn your router to the place where the LAN cables are and just nearby you will see a small button that is abit hidden , so just press that and while pressing it for 5seconds, remove the power cable and plug it back while the clip is still being pressed in the reset button.
Remove that clip from there and you should be able to see that your power light on the router is blinking, wait till it get stable, then all you have to do is login with going to 192.168.1.1 then enter the default username and password which is either admin, admin, or root, password. or root, admin
Then just configure your router again and all shall be well.
THanks.
Hope this helped you.
