Put the piston in with the mark on the top of the piston facing the exhaust port of the cylinder. put one circlip in the piston in the bore seated correctly in the groove. place piston over rod facing correct direction and insert wristpin into piston and through the rod needle bearing in the top of the rod. insert other circlip and seat correctly in groove. install compression rings with letter or any markings facing up. markings usually located at end gap on either side. install oil ring with straight ring on top squiggly ring in center and straight ring on bottom all in the same groove which will be the lowest groove on the piston.stagger all the ring end gaps. do not let all the gaps line up. install base gasket on engine case. clean everything and make sure everything stays clean. slide cylinder over piston and compress rings with fingers and finesse cylinder over piston. do not force. put nuts on studs and tighten to spec in service manual. install head gasket correctly and put head on and put nuts on studs. tighten to spec. reassemble rest of motorcycle and get hurt! have fun
