Posted on Jul 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black Haze we are getting a 1" wide black haze on top/bottom of copied sheet. Image Runner 330s. Ran cleaner modes and did not seem to help.
Chris Coughlin
Level 2:
  • Canon Expert 1,326 Answers
  • Posted on Jul 29, 2009
Chris Coughlin
Canon Expert
Level 2:
Answers
1326
Questions
Helped
441367
Points
872
It can be one of two things... It may be the drum needs to be replaced or it could be the fixinf film is ripped and damaged. It maybe the transfer unit or the developing unit?
1helpful
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Very dark copies on all settings machine sat in storage for a year
clean the mirrors for haze. and check for residual image on the drum for bad c blade
Black haze covering picture after "pop" noise
That's a very old model to be only 1 year old?
It needs a Z-Sustain PCB anyway.
Thanks.
1helpful
Black Sink - white haze
A lot of the soaps and things that we put into our sinks can cause tiny scratches into the glaze. That's what is causing the "haze" you are describing. It's not something that can be lifted off but might be buffed out. I would recommend contacting Kohler and asking if the sink can be buffed successfully. They may be able to give you some contact numbers of people that can repair the sink if it can be. I wish I could offer some more advice but you might be heading towards a replacement instead. Good luck to you!
2answers
3answers
Blue haze on my plasma screen
I had the same problem, I had to send it back to Philips to get a $900 part replaced. Thankfully I had the warranty with it.
Green haze not sharp
Good Day;
Sounds like your TV has a convergence problem. If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram. Or call FACTORY SERVICE;
1-800-448-2244.
Good Luck, big IRISH. PS or get from HIT Part X480293: kit.
Adding Staples Image Runner 330S
depednding on sorter im guessing its the small sorter with one tray the stapler is in the rear of the sorter green handle pull it out uses L 1 staples
old marine
old marine
ZJ Limited
ZJ Limited
