SOURCE: Panasonic KX-TD7896 Phone phone no longer rings only vibrates
Is there an 'M' on the display? If so, that means it is in 'meeting mode.' All you have to do is press and hold the star key (*) and that will take care of it.
SOURCE: when a call comes in the ringer doesn"t ring
you need to have the phone programmed to ring. ldtsnj.com can help
SOURCE: how do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
SOURCE: my iphone won't ring with incoming calls. I have
The only thing i would check is the switch on the side. Make sure its not sticking, or accidentally switched it... If its messed up, im sure Apple would replace yours! :)
