SOURCE: reset navman s
Do the hard reset by this way "Hard reset by pressing and holding the power button for
around 10 seconds, then releasing it and pressing it again for around
10 seconds to turn it back on"..Its a painful one but its the temporary solution which you can do!..Thank you!!..Dont forget to rate my solution in Premium problem buddy....
Regards..
SOURCE: Navman s30 3d 2009 map update is useless
You should be able to install your old map from the DVD/CD that originally came with your Navman - you don't need a Product Key for this, even if it prompts you for one.
It appears that the commercially available 2009 map for the S-Series does *not* cover the S30 3D, just the non-3D versions, although that's not at all obvious from what's on Navman's web-site, so you have my sympathies if you bought it expecting it to work...
SOURCE: I can't load eastern european maps on to my Navman
Hi there, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_edr45f6
