Exactly.
You can only check the connectors between main electronics and user interface. Sometimes due to vibration the connectors lose a good connection, otherwise main board(PCB) or user interface (PCB) is faulty. It is difficult to find out which of them is incorrect.
Only authorized service providers have a interface for connecting to the electronics of the washing machine.
Dado
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
SOURCE: My Electrolux Washing machine has fault code
www.electrolux.com.auGo here and type in the model in the search bar and download the manual for the machine this will help
SOURCE: what does the code 5d mean on my washing machin???
5d is actually SD
it means SUDS
you have suds detected in the pump
Your using too much soap and the machine cannot rinse it
try one load with out any soap
from that load on you should not be using any more that a table spoon per load
SOURCE: electrolux ewf 1090, have an electrolux ewf1090
ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
Hello - Typically error code E9F indicates a communication problem. A certified technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnostic either the wiring, main control board or speed control board would need to be replaced. Contact a professional to move forward accurately.
