SOURCE: Replacing main oven heating element
the element will held in place from the screws inside the oven not the back
SOURCE: Want to replace the heating element
Can you tell me which one is your dishasher to better assist you.
HLD4040NSA
Hotpoint® Built-In Dishwasher
HLD4000NWW
HLD4000NBB
HDA1100NWH
HDA3540NSA
HDA3500NWW
HDA3500NCC
HDA3500NBB
Thank you
SOURCE: E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
SOURCE: Heating element out, dryers runs
replace element but clothes still wont dry helpppppppppppppppp
