MY SAMSUNG J1 IS IN ODIN MODE(Multi core download)Secure download enabled.I went to different repair shop got same ans. they can't fix it. Is there any way or not.? Your honest answer please. thanks
It only tells you if you have a custom rom or an official rom and also that mode will let you download and install unofficial roms using a pc/laptop. Be mindful though that it will void your warranty. If you don't know what your doin, i advise you to just take off the battery to close that mode.
If your Samsung device doesn't have a Home button, it's fine to just press the other buttons. Press and hold all the buttons to exit Samsung Odin Mode together. Press and hold all buttons except the Volume up button. Remove the battery and reboot your Samsung phone.
if you using the PC you should ensure that ( the drivers for this device has been installed and run Samsung kies), sometimes you will facing problems because usb cable.
1. Turn the power off first
2. Slide out the keyboard
3. Power on and press ad hold the 'R' Key
4. In Android system recovery use Vol keys to scroll up and down
5. Use the power key to make a selection.
If you cannot get to a recovery you will need to use ODIN to flash phone to factory state. this "should" fix anything unless phone itself is bad. Here is a ODIN guide for your phone. ODIN is official samsung flashing tools available for free from samsung. Good Luck.
Hope you have bricked your android phone. Now must flash your phone with stock rom. You can do these by using ODIN. Just download ODIN for your phone, download stock rom odin flashable .zip packages for your phone, put your phone in download mode, connect your phone to PC via USB cable, run ODIN , load stock rom packages, flash it..
