SOURCE: AKAI CASSETTE DECK IDLER?
I wonder if it has a counter and if so, is the belt that drives the counter too loose? Is the counter working?
Geno
SOURCE: SLOW ACCELERATION
Change your fuel filter on the front of the carb - if that dont work change the carb, summit racing sells new Q-jets for cheap
SOURCE: akai gx-646 capstan motor runs
You must replace transistor for capstan motor speed ( transistor code is 2SC2336 ). This transistor it is near power transformer.
SOURCE: treadmill goes normal speed until I get on it and
When was the last time you placed the correct lubrication between the walk belt and the walk board. This is a very common issue. Make sure you DO NOT use anything from an aerosol can. The acetone will cause the belt to get dry, hard and crack.
Good luck.
SOURCE: I have a sony TC 530. Fast fwd and rewind work
You need to replace the motor run capacitor. It's a small aluminum can looking thing with three wires right next to the motor; they often leak paraffin wax into the bottom of the case when they overheat. Whether or not yours has leaked it's easy to replace if you can use a soldering iron. Search eBay for a Sony reel to reel 1.5uf 250VAC motor run capacitor - they're less than $15 and come with detailed instructions.
Please wait
Image not available
