SOURCE: voice mail icon stuck on
I had this problem on my pocket pc phone. FINALLY found the answer here: http://thedailyinvention.com/?p=565 hope that helps
SOURCE: remote access to voice mail
from a tt phone, after the message, hit * your ext # and then your pswrd.
it's just like retreiving your messages from an ext not your own.
from there you can change your access info in the admin section.
pause 5 secs and listen to the prompts from the vm syst itself.
SOURCE: voice mail i6725 vtech phone
ACCORDING TO THE MODEL NUMBER THIS PHONE DOES NOT HAVE AN ANSWERING DEVICE. IF YOU HAVE VOICEMAIL - YOU MUST HAVE THE PHONE COMPANY'S SERVICE FOR VOICE MAIL. IF YOU HAVE A STUTTERED DIALTONE WHEN YOU HAVE MESSAGES THEN IT PROBABLY COMES FROM YOUR TELEPHONE COMPANY. CALL THE PHONE COMPANY AND ASK FOR INSTRUCTIONS TO CHANGE THE GREETING ON VOICEMAIL.
SOURCE: visual message waiting indicator
Press the mute/program button, then press the caller ID-volume button
to select handset setup. Next press caller ID-volume until you get to
Default settings. Use the caller ID-volume button to select 1yes. This
will return the phone to the factory settings and for took care of the
blinking blue light, however you will loose any custom setting or
numbers you entered.
SOURCE: new voice mail
This is a cordless extention phone "its base station" must have a answering machine correct?
Well you need to check you messeages on that and clear them out on that and this phone would be cleared as well, if you do not have a base station with a answering machine or voicemail system then your phone company must have one and there sednign these messages down the line to indicate someone left a voice mail on the syste,
Ether or here you did not tell me about the rest of the system so I am cought assuming that is what it is because it is what it is somewhere down the line you have a voice mail ether on a home based system or your telephone company.
Thanks please do not forget to rate. Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
