If it was playing fine and just stopped working while you were playing it, it's possible the speaker has failed, or a wire has come off. It is likely something you cannot fix yourself, and should find a local music store, like Guitar Center, who can repair it for you. It's generally not a very expensive repair at all.
If the sound stopped working from one side after you were playing with some controls or editing some voices, you may have set the panning all the way to the right, which would cause no sound to come out of the left speaker. In that case, you would simply need to set the panning to the center again while in editing mode.
If you are not too familiar with the editing features on the PRS 330, and not sure how to set the panning to the center again, you could always simply reset the unit to it's factory settings once again, while will return all the voices, effects, panning, etc. back to like the unit was when it was first taken out of the box and turned on. Here's the process to reset the Yamaha PRS 330 back to it's original settings -
Restoring the default (factory-programmed) settings
While holding the C7 key (right-most key on the keyboard), press the power switch to turn the power on.
This operation erases backup data in this instrument (including backup settings in the Function mode) and
restores the factory default settings. The User Songs and the external Songs stored to internal memory will be
retained
None of that works and you do need to have someone look at the unit, here is a link to the Yamaha Authorized Service Locator to find the nearest authorized service center near you -
Servicer Locator
SOURCE: i need for :yamaha keeboard psr 9000 :danish manual
hej I asked my lokal store. thank ouy for answer. best regards poulc
SOURCE: yamaha Psr-340
I don't have Cubase myself but there must be a track setting that allows you to monitor what you are playing live. Also make sure your keyboard shows up as the midi controller on the software. Your receive channel has to match the send channel of the keyboard. Make sure that synthA or synthB shows up as the sound source (audio out). XFi Midiport is your midi in but since Cubase already sees your keyboard your problem is an audio one not a midi one. Hope this helps.
SOURCE: Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
SOURCE: some of the keys do not play on our Yamaha
The key contacts have gotten dirty. The contacts are CONDUCTIVE rubber pills that are pressed onto circuit traces on the circuit board under the keys. Onehas to dis-assemble the keyboard very carefully noting the size and location of all the screws and using great care of the cables that connect the top and bottom of the case.
when you remove the keys, you will find silicone rubber strips with the black pills underneath, two pills per key.
Clean these with ONLY 99% isoprophyl alcohol and Qtips as well as cleaning the circuit board traces they contact.
Carefully re-assemble the keyboard.
