Your problem is caused by the fact that the watch is 12 hours out of step.
Wind your watch forward 12 hours, reset the date if you need to and you watch will then change around midnight.
(if you need to change the date more than one day, when it has past the change time, wind it back and then forward to step the date forward. You may have to experiment to see how far past the change point (in both directions).
This is because you have reversed am with pm. Set your watch 12 hours back and the problem should be solved. You might want to wait till midnight or noon to check it's fine.
Note: if you see the day shows the previous day rather than the present day, you have to set the clock 24h ahead. Problem solved!
Since you didnt tell me what KIND of watch it is I am giving you a general instructions.
Wait until the second hand is at zero (the top of the dial). Then pull the crown knob out as far as it will go to set the time on your watch. Turn the knob in either direction and look at the three additional hands on the time dials of your watch: the minute hand, the hour hand and the 24-hour hand.
Step 2
Stop turning the knob when all minute and hour hands are pointing to the correct time. Pay special attention to the 24-hour hand so that you have a.m. or p.m. correct.
Step 3
Push the knob back in exactly when a new minute is starting so that your second hand will be correct. Use another clock you know to be accurate as a reference, such as the government clock available online.
Step 4
Pull the knob out halfway so you can set the date. Turn it counterclockwise until you notice the date on the watch changing. Stop it and push the knob back in to its starting position once you reach the correct one. Try to set the date before 9 p.m. If you set it after that time, it may not register with your watch that it should switch the date at midnight. If this happens with your watch, just fix it the next day.
Step 5
Set the chronograph, or big dial, on your watch. It works like a stopwatch to let you time activities for up to one hour. Push the top button on the side of your watch to start it. Push it again to stop it. Push the bottom button on the side of your watch to reset it.
It would certainly help if next time you let us know what kind of watch it is you have, Best of luck.
Some watches will change the day/date starting at 1130pm and not be done changing both until 230am. So yours may be normal for that particular watch.
BTW, that is when the date does change to the next day, at 1201am.
Hope this helps.
The day changes at midnight but if your watch thinks it is displaying 11a.m. when it is in fact 11p.m., then it won't change over until noon the next day.
Solution; wind your watch forward 12 hours (tedious, I know). You will then need to reset the watch to the correct day.
I suppose when you're setting the time on your watch, passing the midnight marker the date changes. In that case you can go to the date funcion and reset the date. Ciao Giulio
The Skagen watches have two-step stem; fully pulled out will change the time and partially pulled out will change the date (only goes one way so try turning it counter-clockwise or clockwise - I forget which is correct). It's easier to find the date length by extending it all the way and then go back toward the case. It won't change the date if you run it through a 24-hour cycle - you have to do the half-way thing. Hope this helps.
