Question about KitchenAid Microwave Ovens
The display/control panel on my kitchenaid oven model KESC308LSSO is functional but does not light up. What part would I need to fix this? + looking for video of repair
    Scholar:
    New Friend:
  • 70 Answers
I assume the display is hard to see but otherwise the unit function correctly? I'm going to gear my answer to this issue. If everything on unit functions but just can't see clock and temp. settings, you have a bad display. That's gonna be part #2. I'm not how to upload video but go to youtube and type in Kitchenaid slide in electric control replacement. The top video should give you a good idea on how to change display board out. Good Luck
The display/control panel on my kitchenaid oven mo - kitslideindisplay-ymxmjm51p43jahlqvxd5xzz2-2-0.jpg
Posted on Oct 20, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: Panasonic Microwave inverter oven model,
10 Amp fuse blown inside oven.
Posted on Apr 19, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: What would cause the touch
It may be a glitch that can be corrected by a hard reset. Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
It may have gotten moisture, contamination, or grease inside, which can happen if one cooks on the stove top without having the microwave's hood vent fan on.
It may simply need repair.
We repair microwave control units and touch panels / touch screens for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 02, 2008
Anonymous
SOURCE: Control Panel for Sharp Carousel Microwave Oven
would you help me to find..
driver Acer Nplify 802.11b/g/Draft-N WLAN
Posted on May 07, 2009
roberta3fan
  • 574 Answers
SOURCE: GE microwave oven, portable, model JE160SF001, no
It is probably the main fuse. You'll have to remove the microwave and take it apart. There are several screws around the microwave that you'll have to remove. Just be sure when you take the scres out you know where they go back because they may or may not be same size and they have to go back exactly where they come out. Once you get the cabinet off the frame follow the power cord up until you see the fuse. It will more than likely be a ceramic fuse around 20 amps, take to maybe a lowes, home depot or radio shack and one of these will have the proper fuse.
Posted on Feb 03, 2010
seth adams
  • 1531 Answers
SOURCE: Kenmore Microwave Oven, Model#66568680891
you should change the touch panel and or the control module.check to make sure the power supplied is correct and all connections to the board are all secure.
Posted on Feb 24, 2010
I need owner manual for kitchenaid kesc308lsso
You can download Whirlpool / Kitchenaid owner's manuals and installation instructions here.
Oct 07, 2011 | KitchenAid KHMS155L Microwave Oven
KitchenAid KCMS1555RSS - display completely blank and does not function. Is it worth fixing?
i would try and see if the fuse is blown in unit ... normally behind control panel there is a in line 20 amp fuse that may have blown.... if the unit makes noises when you touch the buttons but no display then you have a bad control board assembly
Jan 11, 2011 | KitchenAid KCMS1555RSS Stainless Steel...
Microwave and display panel are not working. There is power to the electrical ground fault interruptor box and it is not tripped. Could it be the fuse inside the unit itself? I can see a fuse behind the...
Since you posted this under model KHMS105EBL, I'll assume that's your model number.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your full model number with no dashes).
You can also find helpful exploded views and order parts here.
This model has a line fuse, an oven cavity thermostat, and a magnetron thermostat, any of which can render the oven "dead".
If those components are good, then you may a problem with the control circuit board. More info here.
Accessing some components (like the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you need more help, let us know.
Aug 10, 2010 | KitchenAid KHMS105EBL Microwave Oven
How do I unlock the key pad? The display shows locked and I don't know how it locked.
Here you go.
The Child Lock shuts down the control panel pads to prevent
unintended use of the microwave oven.
When the control is locked, only the Vent Fan and Light pads will
function.
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound
and a lock icon appears on the display. Repeat to unlock and
remove the lock icon from display.
May 10, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Will not operate. displays f2
F2 means you have a shorted membrane keypad.
On some models, you can get the membrane keypad replaced by a servicer or your can do it yourself, but on some models, you would have to order a new control panel frame which comes with a new keypad.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Apr 25, 2010 | KitchenAid KHMS155L Microwave Oven
How to remove the controls panel cover. Our 12 yr old microwave suddenly stopped. No power to display or oven. I have been told that there is a fuze behind the display that is replaceable. Trying to get...
If it's an Amana, WHirlpool, Kitchenaid, etc., and you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you need to remove the oven from the wall, the the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool here.
You can download GE owner's manuals and installation instructions here.
Apr 15, 2010 | GE JE1390 Microwave Oven
Microwave shows F2 on display with controls non functional
HI. this is a code that represents a failed key pad or touch pad membrane board. replacing this failed touch pad will fix this issue. This touch pad board is separate from the actual control board.
Aug 13, 2009 | KitchenAid KHMS155L Microwave Oven
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
Kitchenaid microwave oven KBMC140HSO
I started having the same problem with my KBMC140HSSO. You cannot see the error codes without disassembling the control panel (the codes are on another display that covered by the front panel). After doing so I found the error code to be F2, E3 which is "Key held down too long, or key shorted". I am ordering a replacement keypad and will report back if this fixes the problem.
Mar 29, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
374 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
