Computers & Internet Logo
osei gunthorpe Posted on Sep 18, 2017
Where can I find schematic and boardview of intel D915GEV motherboard?
amjakati
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Oct 05, 2017
amjakati
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
19098
Points
30
On the motherboard website, it should be under technical specifications.. else check on google images - somebody would have put it up
4 Related Answers
Anonymous
  • 32281 Answers
  • Posted on Feb 25, 2011
SOURCE: How to Bypass or Remove
Remove the BIOS battery for 15mins then insert it back. Boot up the computer and go to the BIOS configuration and set the date and time etc.
Anonymous
  • 2574 Answers
  • Posted on Mar 01, 2011
SOURCE: I need the SATA driver
Intel SATA Driver Intel Ver.7.0.0.1020.zip -->click Here to download
Anonymous
  • 326 Answers
  • Posted on Dec 24, 2011
SOURCE: D915GEV mobo won't start
I would reseat your processor. Make sure it's in there properly. Then make sure your processor fan is installed correctly and is plugged in.
Reply back with your results.
Anonymous
  • 2878 Answers
  • Posted on Aug 26, 2012
SOURCE: Hi...my OS is Windows 8 and I can't install my motherboard Intel D915GEV graphics card...please help me... ... ...
Here is the official Win 8 Compatibility site:http://www.microsoft.com/en-us/windows/compatibility/en-US/CompatCenter/Home
Suggestion: Always test OS and software on VMware and keep checking Intel for updated drivers. Good luck.
Is it possible to connect 500gb internal sata hard disk to motherboard d915gev
If the board has sata connections on it then yes it will work fine
Can i connect sata internal hard disk 500gb with d915gev motherboard
I dont think that is possible seeing that, the motherboard only has IDE cables, If it has a SATA port go for it
How to Bypass or Remove a BIOS Password , Intel D915GEV Motherboard
7helpful
4answers
Will the D915GEV support window7
Yes: Windows 7 can be used with this board.
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Here's the specs on the D915GEV
(See PDF Manual)
Click here:
D915GEV Technical Product Specification [PDF]
The Intel 915G chipset consists of the following devices:
• Intel 82915G Graphics Memory Controller Hub (MCH) with Direct Media Interface (DMI) interconnect
• Intel 82801FB I/O Controller Hub (ICH6) with DMI interconnect
• Firmware Hub (FWH)
The MCH is a centralized controller for the system bus, the memory bus, the PCI Express bus, and the DMI interconnect. The ICH6 is a centralized controller for the board’s I/O paths. The FWH
provides the nonvolatile storage of the BIOS.
Supported Memory Configurations.
Up to : • 4 GB maximum total system memory.
Processor:
The board is designed to support Intel Pentium 4 processors in an LGA775 processor socket with an 800 or 533 MHz system bus.
Note: All processors available for this board are in excess of the 1 gigahertz (GHz) minimum requirement for Windows 7. (see here) http://www.intel.com/support/motherboards/desktop/d915gev/sb/CS-026957.htm
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks.
1helpful
3answers
Where do i download intel d915gev drivers.I lost my CD
Get connected to the internet to download the software
driver for your motherboard.
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
