SOURCE: Hi, I have a panasonic
You certainly have a n application managing the wifi signal,start that app.
and you should have control on it.
or go to services by rightclicking my computer and leftclicking manage
Services is nearly the last , then in the sevices list, locate wireless zero config, and if not activated & started, do it.
Wifi should then awake by itself
SOURCE: moto v6 keypad problems
Hey,
I have or should I say I had the same problem with my v6 maxx keypad not working. So I started to look into the flex cable replacement idea. I remove the back cover. Removed the Sim Card, Battery and Memory card fully intending to split the phone and have a look around inside. But then I came to a grinding stop when I saw how small the hex screws are. Gotta get me some of those. While I was there staring at the screws I noticed a small amount of dirt residue inside the back of the phone so figured it wouldn't hurt to give it a spray with CRC Contact Cleaner (it leaves no residue). I left the mobile in the sun to dry for about 3 minutes. Replaced the battery, memory and sim card and now it's working PERFECTLY.
Done. fixed. *** twas just dirt.
Cheers
roddarockker
SOURCE: Drum replacement -- "Option" button not avail. to complt install
open front cover first, then what you tried will work.
razors
SOURCE: Stuck in manual mode
Check that the wide angle pull out filter is pushed in proberly until it clicks in place also in custom menu check that M ZOOM is set to OFF. (hold zoom and - buttons together for a couple of seconds to enter and exit custom menu)
SOURCE: We can't see the bottom of website pages. For
Open the device manager and see if the correct video drivers are installed. It will show like Nvidia or Radeon or somthing like that. Thats what i would check first. If it says generic device then you have found the problem hope this way helpful :)
