SOURCE: GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
SOURCE: Inglis washing machine won't spin
Turn the timer indicator to the asterisk * start it up. It should agitate without no water in it. If it don't agitate you have a bad coupling part number 285753 whirlpool. Google it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: SPEED QUEEN TOP LOAD WASHER HA4011W. Motor trips at SPIN start
I would call whoever repaired the washer back out and have them diagnose.
SOURCE: Operates correctly on all wash,rinse,soak cycles but does no spin
Check the door switch, if it's faulty the spin cycle will not work, but everything else will.
