SOURCE: Mitsubishi rear projection tv problems
this problem is going to be several bad capacitors on the signal board inside your tv. i suggest calling a technician
SOURCE: 52 inch RCA big screen
check all connections and different sources(dvd, vcr, antenna) to make sure that it is the tv. otherwise i would say call a technician because you could be in for some extensive troubleshooting
SOURCE: Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
SOURCE: Samsung HLN617WX/XAA 61
Did you ever find problem. This is what mine is doing. I'm going to replace color wheel.
