SOURCE: Power Shot SD550 Date Stamp
Dear BethSmith,
I have had the same problem for a long time. It has nothing to do with the battery, etc.. It has to do with the software of the camera.
You are only able to have time stamps on the photos when you are in the postcard mode. (resolution will be set to 1600x1200, at fine setting) Check out page 29 and 39 of Advance user manual!
Good luck,
Shah
SOURCE: Putting the date/time stamp on my pictures
I have the same problem, if someone solved this, please let me know [email protected]
SOURCE: Date and Time Display on Downloaded Video
I suppose that .MOI is the solution, maybe in this file there is details about time, date... Only we need to find out how to merge .MOI & .MOD...
SOURCE: HELP! Getting the date/time stamp off your Vivitar 5100...
When you turn on your camera, press the menu button. That will bring up the screen that has the orange buttons at the top (Capture) (Setup) arrow down using the buttons on the far right side. The down button will be the dame button that you use to delete pictures with. When you get to the botton of the page continue arrowing down and that will bring up another page. Arrow down until you get to the botton there are only 3 items on this page and the bottom item will say the following:
Date imprint ON
Press your enter button (ok button) and up will pop ON or OFF.
Arrown down to the OFF and press enter and that will remove the date imprint from your pictures.
Hope this helps you.
SOURCE: Show/print date stamp on my photos
In order to imprint the date stamp on photos, the photo size (L, M1, M2, M3, S, Postcard) must be set to Postcard, and in the recording menu the "Date Stamp" option must be set to Date or Date & Time.
Testimonial: "Perfect! Thank you so much..."
