Televison & Video Logo
E
Eleanor prytherch Posted on Sep 16, 2017
How can I find my wife's google account details on her asus tablet
She turned off last night,turned on this morning,it will not come on we find the google details
5 Related Answers
Anonymous
  • 1543 Answers
  • Posted on Mar 06, 2011
SOURCE: Wife put the oven on clean cycle last night. This
You probably just need a new bake element. Many ranges supply 120 volts to one side of the bake element at all times, switching the other side of the 240 voltage to it (and completing a circuit) when it needs to heat. If the element shorts to ground, the 120 volts can heat though a section of the element to the ground. OK, so much for the technical stuff. Turn power off to range. Replace bake element. Re-connect power. If it works, great. If it heat without turning oven "on" now, that would indicate that the electrical contacts in the bake relay on the control board have welded themselves together, necessitating replacing the control board. Let's hope you are not unlucky enough to have had that happen. (sometimes that happens as the result of an element failure)
Anonymous
  • 1386 Answers
  • Posted on Jun 09, 2011
SOURCE: my wifes 2004 Mini cooper
Hello and welcome to FixYa!
As a first course of action, please check if you have fuel. It can be the reason why it won't start. If fuel is good then the problem can be on the fuel pump. If the fuel pump is faulty, it won't sip fuel from the tank going to the engine. A humming sound on the engine will indicate that the fuel pump is working, if you don't hear anything then the fuel pump must be replaced.
Hope this helps and thank you for using FixYa! Have a good one!
walesarumi
Wale Sarumi KomputerSolution
  • 6993 Answers
  • Posted on Jun 24, 2011
SOURCE: how to reset sony ericosson
The Sony Ericsson Xperia X10 is highly customizable and you have been hard at work tweaking it to your liking, but now the fun is over and you want to return it to its factory settings again.
Here, we show you how to hard reset the Sony Ericsson Xperia X10 with step by step instructions.
Please note that all data will be deleted from the Sony Ericsson Xperia X10 as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
1. From the main home screen, tap menu
2. Tap Settings, then SD card & phone storage
3. Tap Factory data reset
4. Tap Reset phone
5. Enter your password, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
1. Turn the power off. If your Sony Ericsson Xperia X10 is frozen, pull the battery out and reinsert it
2. Hold the Left and right buttons located beneath the display
3. Press and release the Power button
4. Follow the on-screen instructions to hard reset your Xperia X10
All data including third-party applications will be deleted from the Sony Ericsson Xperia X10. Once the wipe is complete, the phone will reboot to its factory fresh state.
Regards.
Anonymous
  • 32281 Answers
  • Posted on Jul 18, 2011
SOURCE: I purchased an Asus EeePad
You need to connect to your wireless router that is connected to the Internet via a cable or DSL modem OR to a Internet cafe WiFi hot spot at a location such as McDonalds, Star Bucks.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
kishore_0077
  • 86 Answers
  • Posted on Dec 24, 2013
SOURCE: google play wont dowload my apps
Better to reset your tab once...
Polaroid tablet: What to do?
It is called Google FRP and it is the details that you put into access the Google Play Store. It also there to stop theft. Just log in with your Google Account or the account of the person that bought it.
You have to be signed in with the "owner" account of the phone (the one you used to set it up) in order to factory reset it. That means if you give me your phone or Tablet, I can't reset it without you being signed in. There are random workarounds on the Internet, but they tend to get patched almost as soon as they are discovered. You'll pretty much need to know the login details for the last account to use the phone before you can reset it and create a new owner account.
Videos here
https://www.google.com/search?q=Polaroid+Tablet++Bypass+Google+FRP
How do i root my asus tf300t without a computer?
xda developers .com. sign up then type in your question. make sure you have "installation of unknown apps" turned on in your personal settings and also in google account settings.
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
1helpful
My husband has a nextbook 8 tablet and he downloaded a game from google play store last night and then shut it off and this morning he turned it on and all his apps are lost and Wi-Fi is also lost, he
Im guessing that the app/game was corrupt or incompatible with your tablet. You will have to reset your tablet to factory settings and restore your apps and other items from google, if you had it set up for this. To do a reset go to settings - about tablet - reset - factory. Then let it restart.
ASUS pad tablet wont turn on
hi celeste.
see if this link will help you sort it out.
ASUS pad tablet wont turn on Google Search
On front screen its come up with "Unfortunately, system UI has stopped" report or ok. But it wont let you do any thing. I only just set it up last night. It wont even let you turn it off completely.
After researching about this online, it seems to be a software update issue. You can try to do a factory reset, and if you can get into apps, you can try downloading a "face lock" app, which seems to help as well. I hope that this helps!
Help for nexus 7 tablet
Are you trying to connect the Nexus to the internet via your computer? using ad-hoc wifi connection?
I followed these instructions and was able to make the connection.
Hope it helps.
Dan
2answers
Incessent beeping and won't boot
you told that your PC was ok last night. and again told at morning when you started it then it started giving beep. there may have 2-3 problems.
1. your processor has become loose, so unplug and plug the processor again correctly.
2. cooling fan can't cool the heat sinker properly. so test it that if the cooling fan is working properly.
3. The RAM can be loose. So test the RAM. Unplug the RAM and then plug it perfectly.
but you told that you PC is starting and then shutting down giving a beep. so i think you PC problem is number 2. and I hope you follow the number 2.
Sony TV won't turn on :-(
our power went off last night for three min and when it came back on we could not get one channel. this morning my wife turn on our television and it worked fine. my wife went to turn it on tonight and it will not come on from the remote or at the bottom of television
Top ASUS Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ADMIN Eric
ADMIN Eric
Are you an ASUS Televison and Video Expert? Answer questions, earn points and help others
