They both hook to the throttle body the throttle cable runs in the fire wall the other runs to a black box under the hood on the right side of the car
SOURCE: not getting any gas, abuzzing noise under hood near where throttle cable hooks
could be a bunch of things, possibly a bad injector relay, will need to have someone troubleshoot the fuel injection system. Have you checked the fuel pressure?
SOURCE: do not know where to hook - cable to charge battery in bmw 540
THERE SHOULD BE AN AVAILABLE CONNECTION UNDER THE HOOD ITS LIKE A BIG BOLT WITH A COVER WITH A PLUS SIGN, SOME ARE BY THE INTAKE SOME ON THE FIREWALL .
SOURCE: wiring schematic for plymouth grand voyager 1995
Is there green corosion on the tip of the wire ? Chances are the answer is yes. You will have to detach the fuse panel/box and run a new wire and connector to the fuse panel. Splice into the wire you can see, but make sur you cut enough of the wire off to get rid of the corrosion.Hope this helps.
SOURCE: need to hook up the throttle cables to the
Usually if you look at how they clip on to the bracket, they only go 1 way.
SOURCE: vacum hose
There are several variables here. First, it must be determined if your vehicle is equipped with emission controls that were certified for sale in California. (This makes a big difference on vacuum hose routing) Then, there are different diagrams for early 1993 models and late 1993 models. My recommendation is to either buy the Mis=tsubishi shop repair manual for your vehicle, or subscribe to an information service such as AllData DIY. That way, you can look at the diagrams and compare them to what you actually have under your hood. AllData DIY is currently available for a single vehicle for only $26.95/year. It has all the service information you could ever need for your vehicle. Click the following link to check it out. AllData DIY
