Alfa Romeo 156
Fuse box in passenger compartment Alfa Romeo 156.
fuse box location.
The fuses for the main devices are housed in a control unit under the dashboard, to the left of the steering column. To gain access to them, remove the panel (A) releasing the tabs (B) in the direction of the arrow below and remove the screw (C).
fuse box layout.
Ignition auxiliary circuits relay 1
Heated rear window relay
Horn relay
F1
(10A) RH headlamp- high beam
F2
(10A) Headlamp high beam warning lamp, LH headlamp-high beam
F3
(20A) Boot lid/tailgate lamp, central locking
F4
(10A) Headlamp adjustment, RH headlamp-low beam
F5
(30A) Electric windows(front)
F6
(10A) LH stop lamp, LH tail lamp, RH licence plate lamp, RH rear fog lamp, RH side lamp
F7
(10A) LH licence plate lamp, LH rear fog lamp, LH side lamp, RH stop lamp, RH tail lamp
F8
(10A) LH head lamp-low beam
F9
(15A) Cigarette lighter, heater/air conditioning (AC)
F10
(20A) Wind screen wash/wipe system
F11
(20A) Horn
F12
(10A) Alarm system, anti-lock brake system (ABS)(with ESP), audio system, instrument panel, interior lamps
F13
(10A) Anti-lock brake system (ABS), central locking, electric door mirrors, electric windows, glove box lamp, reversing lamps, stop lamp (high level)
F14
(10A) Hazard warning lamps
F15
(30A) Door mirror heater, heated rear window
SOURCE: cigarette lighter socket not working
The fuse for the cigarette lighter is the 15 amp CIG fuse. According to my wiring book, the fuse box is either behind the console, passenger side for US cars, or under the dash, driver side.
SOURCE: cigarette lighters out
check wiring behind each cig lighter or use test light inside the socket
SOURCE: 1995 camry wagon cigarette lighter not working
start with a test light and check for power at the center of the cigarette lighter socket. If power is good, then check for ground at side of lighter socket.
If no power, run wire from power wire of lighter to power wire of stereo, thus tapping the power directly and bothering to trace out where the open int he circuit may be.
SOURCE: Cigarette Lighter not working
The front lighter is powered by fuse 24(20 amp) in the interior fuse panel and the other lighter or power point is powered by fuse 12 (20 amp) in the under hood fuse box
SOURCE: 2003 pontiac grand am cigarette lighter does not work
no, are you checking the lighter with the ignition in the run position?
