You have one yellow, two red, and two black wires for a five-wire security camera color code.
-> The yellow wire is the positive (V+) video wire.
-> The red wires are positive electrical transmission wires.(DC+)/(IR+)
-> One black wire is for negative (DC-) power supply;
--> other black wire is for negative (V-)/(IR-)Video/Infared
Best of luck folks
That is why I do not use wire devices in a security system. Also, all the products I use work without an Internet connection as they have a sim card. By the way, I use the Ajax security system. I am not sure if every brand has such progressive products, but Ajax does. I recommend you to check their product opportunities on their website https://ajax.systems/ . I used to have an old security system before, and after I installed that one, I was a little shocked by all the functions and comfort it provides!
Generally speaking, an analog camera's wires are color coded. Red and black are the power feeds. Probably 12vdc. Yellow is your video feed, most likely coax at some point. I don't think anyone can tell you how to hook it back up with the information you provided, or lack there of.
I'm here with the same question. Sad that there's only one answer with no link (although it was mentioned). Maybe anyone else can help with it?
Here is the link to the manual. you might be able to find a phone number of their tech support to resolve your issue.
SOURCE: MOTHERBOARD WIRING
Instructions should be in the manual found here
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=302
They sound like they are for your from usb posts on case...but thats just a gues :)
Hope that sorts it for you?
SOURCE: How would I wire a Bunker Hill BSo8 security camera to a Acer C720 laptop?
try using a USB connection from the camera to the laptop. then use the driver cd that came with the camera so that the lap top recognizes the camers
SOURCE: Rca wires on bunker hill security cam are red black white and yelliw need a diagram to help rewiring
black is power,yellow is video,red and white are audio left and right
Hi Jason:
Here's a link that should resolve it for you.
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=standard%20trailer%20wiring%20diagram
Cheers
SOURCE: cut wires on bunkhill weatherproof security camera#95914
My bunker hill has a black, white, yellow and green. I am confused with the white. Help
