Washing Machines Logo
SHAJAHAN Posted on Sep 12, 2017
I am using super general washing machine sgw720 but now delay washing light blinking only,some time 23 then 3 this displayed and blinking I can't use the machine.so what is the problem any body can help me?
5 Related Answers
Anonymous
  • 725 Answers
  • Posted on Aug 23, 2007
SOURCE: Can't set time delay.
Would your start button be stuck? check to see if there is something keeping it pressed in? if not your control star button could be shorted...let me know
DENNIS MITCHELL
  • 1003 Answers
  • Posted on Feb 02, 2008
SOURCE: Hoover Hnwf 7148 washing machine
REPLACE POWER CONTROL MODULE
joboo1
Jim London
  • 257 Answers
  • Posted on Feb 08, 2009
SOURCE: washing machine won't start. when hit start 0' displayed
Hi, Unplug the unit from AC power for 30 seconds to 1 minute, This should reset it back to the defaults. Good Luck!
ginko
Ginko
  • 19396 Answers
  • Posted on Feb 18, 2009
SOURCE: I have the hotpoint BWM129 super silent 1200 spin,
The flashing lights means that an error had been detected.
The machine must be unplugged from main to check the drain hose and the drain pump.
The most common is that the drain pump is clogged with debris and must be unlocked.
Anonymous
  • Posted on Jun 27, 2009
SOURCE: hotpoint washing machine aquarius super silent wf620
Dear stacey
Had a similar error message
turned out I hadnt turned the water taps on
check this and if not the problem could be the water sensor in the drum
G
Super general sgw720 washing machine can't spin. when starting for wash it shows 42 min.it stops 27th min.then just rotate tub it starts and again 17th min same issue.we set only spin same issue
i don't know. i repaired same condition on different washer. it was the lid safety switch/pin contact. i tested
by pushing pencil in hole where safety pin goes.
DO NOT USE MACHINE WITHOUT WORKING LID CLOSED SAFETY LOCK. you could break an arm / hand.
i slid top off washing machine and moved lid switch back so ' lid pin ' would contact safety switch. if this is the cause, you may need to replace this low cost switch.
What is "delay wash" & how is it operated?
If you're washing machine is equipped with Delay wash.The delay start feature allows you to determine when you want the next wash programme to start. This is particularly advantageous if you want to use night time electricity tariffs or if the programme needs to be finished at a certain time, for instance when you come home from work. You can postpone the start of a programme by up to 24 hours. The display also indicates when the current programme will finish.
2answers
Error 2 super general washing machine
I have super general washing machine model is sgw 620 this machine coming error E5
Super general SGW720. What is error 'E4'?
Run the machine empty to see if you can clear some of the soap residue, E-4 is "suds lock" error and is usually due to using too much detergent. Switch to powdered detergent and only use about a tablespoon full per load
How to used super general sgw 5800
I do not know how to use Super General washing machine SGW 5800 I recently moved to a furnished apartment in Dubai I found this washing machine i could used it 1 time after many trails and after that i tried to operate it again but no hope. ...please help me
3helpful
2answers
How to cancel delay start
Press the Delay Start button several times until the displayed delay start time is cleared or reads "00". Unplug the machine or flip the circuit breaker to the OFF position for at least half an hour or so to forcibly reset the control if pressing the Delay Start button does not alter or clear the displayed delay start time.
Hi there I have Hotpoint BWD 129 washer-dryer. The door looked led started blinking rapidly and "delay start" and "super wash" lights and also blinking and machine is not working. Please can you...
i'm giving my e-mail adress so i can help you more and it won't coast you a thing. i will continue to help until you get it working again. it's [email protected]. feel free to e-mail me any time.
Thank you
Richard
1helpful
How can I reduce the time needed for a wash ? It takes 2 hours is there any way to make it less ?
Most machines have a soil level selection (light / normal / heavy) and if you select light soil level the wash time is reduced. Also, some machines have a " Quick Cycle " which cuts a lot of time off, which should only be used with lightly soiled clothing. Additionally, make sure you have adequate water pressure, and that the inlet screens are clear so that the cycle is not delayed essesivly due to slow water fill. Regardless of all these, the higher spin speeds of a front loading machine (those have the longest wash times, due to the low water use and the tumbling wash action used vs an agitator in a top load machine) will result in reduced dryer run time, thus helping to reduce the overall time a load takes to wash and dry. (although still longer than most top loading sets) Generally, the energy savings and larger load sizes will outweigh the extra time the machines take.
Top General Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
How-2-Repair.com
How-2-Repair.com
Are you a General Washing Machine Expert? Answer questions, earn points and help others
