SOURCE: Ryobi 18V lithium battery won't charge
Hi, Thanks for getting back to me. The yellow and blinking red indicate a defective cell. Since it has lithium cells and is that new any repair to it would be a waste of your time. Ryobi tools purchased in 2008 have a 2 year warranty. I am guessing you probably got it at a home depot and you should return it under the warranty. All new Ryobi tools have a three year warranty. Good Luck! and Thanks for using fixya!
SOURCE: I lost my battery charger and i need to charge my camera battery
I lost mine too and did a search on ebay found one from hong kong that worked just fine it was cheap too! just search ebay.
SOURCE: Set will not power on.. Blinks red LED 8 times
It's a power supply related problem.
The flashing 8 times is a trouble code. A Service Manual for your TV model will have the info on the codes. It could be a bad capacitor or a transformer on the power supply board.If you have some electronic experience, you can find a Service Manual for your TV over the internet. Cost about under $20.
SOURCE: ryobi 18v lithium battery won't charge
sound to me like you have a bad battery, a lot of ryobi batterys don't last like they should i have had the same problem, but my battery was less than a year old and i took it back and they give me a new one.
SOURCE: ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
