The hagtag file is still in printing state but the zebra s4M doesn't print...Please help me solve problem??????
SOURCE: Zebra S4M Thermal Lable Printer Not Printing Correctly.
Is the Media guide st corectly?
This link is for a datamax but all label printers are stuctured the same way.
check
http://www.posguys.com/download/88230401_a.pdf
SOURCE: Zebra LP 2844 fuzzy print
1. Clean the print head with cleaning pen.
2. Adjust print speed/darkness in software.
3. Check the media and verify that print surface is facing up.
4. Check that correct thermal media is in use.
SOURCE: zebra s4m error condtion paper out
Sounds like you will need to perform the calibration procedure.
when you access the menu system go to advanced menu, the password is 9999, use the keys to navigate to manual calibration and follow the instructions. when it states load backing this is refering to backing paper, so remove the labels from the backing and place in label path. hope this helps
SOURCE: Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
SOURCE: S4m is not printing
zebra s4m barcode printer ,suppose if i print 10 Labels only 2 Label come out balance 8 in memory .then printer comes pause, disply showing paper out /ribbon in/please help me....
