To reset that thermostat you press and hold the up and down arrows at the same time. It is possible that a voltage spike has affected it. If that does not work then you need to check the wire connections to it.
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. To manually operate the unit just set the thermostat to heat mode and the fan to auto. Press the hold button one time then set you desired temperature.
I ASSUME YOU DON'T HAVE A REMOTE FOR YOUR TV EITHER SO...
I WOULD EITHER PURCHASE AN INEXPENSIVE UNIVERSAL REMOTE COMPATIBLE TO THE DVD PLAYER AND EITHER USE PATCH CORDS, OR AN A/B SPLITTER, SO YOU CAN GO OUT THE DVD INTO THE TV...THE SAME AS YOU WOULD HOOK UP A VCR.
YOU DON'T NEED A REMOTE FOR EITHER, YOU CAN TURN BOTH ON AND OFF MANUALLY...
YOU ONLY NEED TO MAKE SURE THE TV IS SET TO THE SAME CHANNEL AS ON THE DVD PLAYER 3 OR 4.
HOPE THIS HELPS! I WOULD APPRECIATE A RATING FROM YOU.
