SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
SOURCE: Fast blinking timer light and tv will not turn on
it sounds like the 1000 mfd 16vdc caps on the dm board have gone bad, but with out a model number it is hard to be sure..
SOURCE: anti theft device for 97 ford expedition
I have 2007 expedition XLT and the interior light blinking all the time what the solution ?
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
SOURCE: Mitsu WD-62725 green light blinking continuously.
pls check remote aur repair smps power supply of tv
