SOURCE: Computer very very slow
This problem is probably because your system is infected with spyware,adware or some kind of malware..
Download an anti-spyware software like Spybot Serach & Destroy(Its free and awesome!)Scan your PC and remove all infections and it will be fine!
SOURCE: slow
There are multiple reasons why this could be happening. The most odvious would be the disk but you say that it looks fine. Next i would try to reset the xbox hard drive cache which involves a couple steps. "To perform the function, access 'memory' in the system blade, and then highlight the hard drive. Now press: Y, X, X, LB, RB, X, X. The following message should appear: "Do you want to perform maintenance on your Xbox 360 storage devices?"" After doing that does it improve the load times in the game? If that doesn't help it is most likely either the drive or the saved game. To test the drive try playing another game. If that works fine and loads at the normal pace then it is your saved game might need to be deleted. (If you have or can get ahold of a memory unit move the saved game to that and then delete it from the hard drive and test it. Afterwards you can then move it back over.) How that helps.
SOURCE: Printer running extremely slow - takes forever to print 1 page
go intothe set up and make sure that is is not set to spool documents. you want it to print directly to the printer. thanks for using Fixya!
SOURCE: e-bay page not working properly
Hey,
This seems to be a problem on your computer, I think you will have to get someone to look at it to see what the problem is, I can't really say over the internet what it is, I could guess.
Let me know if you need anything else.
Thanks,
Ekse
