John Crawford Posted on Sep 08, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I program my 12 pre-sets on my Sirius car radio?
Vernon Taylor
Level 3:
  • Sirius Master 7,446 Answers
  • Posted on Sep 08, 2017
 Vernon Taylor
Sirius Master
Level 3:
Answers
7446
Questions
0
Helped
1956038
Points
26207
Most presets are programmed by tuning in to a desired radio station and then pressing and holding the preset button of your choice when usually one of two things will happen - either the audio of the station will disappear and return after about 5 to 8 seconds or there will be a beep after 5 to 8 seconds. In both cases the station will be stored in that preset.
Sometimes special instructions apply but mostly the above or some variation of the above will work. Once you have spent a while pressing buttons the process usually becomes intuitive.
4 Related Answers
Anonymous
  • Posted on Jun 19, 2008
SOURCE: Radio Antenna Adapter for Sirius radio add-on
Brought problem to my trusted auto mechanic and he found a simple disconnect/connect where to antenna cable comes into car under front right side under the glove box. It took literally 30 seconds to do.
Anonymous
  • Posted on Jul 09, 2008
SOURCE: Satellite Radio
 Yes, but it will require a tuner adapter so that your deck will properly recognize XM. However for my deck I noticed that "Sirius" will still be displayed as the satilite provider on the display menu. Confusing but don't cause much concern.
Daniel Shea
  • 30 Answers
  • Posted on Aug 27, 2008
SOURCE: Lost ESN number in Kenwood Radio
It would help if you supplied the model number of the radio?
Thanks Leadispenser
ee-nonsense
  • 29 Answers
  • Posted on Jun 07, 2010
SOURCE: I can't figure out how to set up the Sirius radio.
for xmd3:
press and hold the T button for 2 sec
press search up/down until "SID Disp"
press "cat" button (play/pause)
1st part of sid will display
vol up/down for 2nd half
Press T to exit
Sirius radio problems
I would do the following, hoping one of them works.
1) DISCONNECT the power to the radio and SiriusXM unit to "clear" it. Then reconnect and ask Sirius to resend signat.
2) Ask Sirius to UNSUBCRIBE that radio so it is deactivated. Then, have them reactivate and resend programing signal.
3) Be sure your car is outside under clear sky when Sirius sends the program signal.
4) It is possible the antenna cable to your unit is loose at the connections and/or damaged. A weaker signal may get your stations, but may prevent the additional Navigational signals. Have the antenna checked thoroughly and tested. If car is still under warranty, this should be a covered diagnostic/repair.
5) Finally, be sure the correct Radio Serial Number is being activated. If your radio works, that is one service. But maybe they are putting a wrong number by some chance into the system to fix this one? For example, you have TWO radios in TWO cars. Are they sending the turn on signal to the WRONG radio? Not as farfetched as you might think.
How do i find the sirius id on the panasonic cq-hr1003u?
The radio does not have a Sirius ID - it is not built in. THe CQ-HR1003u is Sirius READY - meaning... The CQ-HR1003U can control an optional Sirius Satellite Radio tuner by Panasonic (item #133SRT100).
In addition to the Sirius tuner, you will need an antenna and subscription in order to receive Sirius Satellite Radio programming.
Thanks!
Why can't i get oprah on my sirius radio [email protected]
On Sirius radios, some programs require a subscription to the "Best of XM" and on some XM radios, you need a subscription to the "Best of Sirius" to get their programs. Call XM/Sirius and ask them, but I think that you have to pay extra for the "B.O.XM".
Tone in sirius radio using aux. input
Do you have a thicker audio cable you can use? It might cut down on the interference that way.
1helpful
2answers
Eclipse CD2000 has no sound from a cd or sirius... radio works
If you have an amplifier hooked up make sure that the correct blue wire on the harness is connected. One of the wires is the remote amp turn-on, the other is for a power antenna. That would be why your radio plays through your speakers, the power antenna wire' when the source is set to radio, sends a 12 volt signal. That would turn on your amp if thats the way that its hooked up.
Backseat-tv not work
Go to the Chrysler owners website and download the owner's manuals, it is all there.
Power supply to Sirius Radio
yes, some sirius radios work on 5 volts, and some work on 12 volts. Your sportster replay is a 5 volt unit. If you trace that wire back, you will find a cigarette lighter plug with a transformer built into it, with either wires soldered to the terminals, or a female cig plug wired up behind the dash. Whatever sirius unit you plan on hooking up, I strongly reccommend using the transformer that it came with......however if you're willing to take a chance, it's most likely 5 volts.
Top Sirius Audio Players & Recorders Experts
John
John
ZJ Limited
ZJ Limited
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
