SOURCE: Cable Type needed for Advent AW-820 wireless speakers
If I recal correctly these hookup like computer speakers with a 1/8" stereo line with a male plug on it. What you can do is buy the "y" adapter for using the RCA outputs on most devices and use these that way, or you can use them through a headphone jack etc. The adapter is a 1/'8' or 3.5mm Stereo female plug going to (2) RCA Male jacks. usually they come pre labeled red for right and white for left.
SOURCE: vertical colored lines from pc to tv scan converter
not likely. it may have something to do with the older computers video driver. check with the manufacturer of the video card for an updated driver.
SOURCE: i need instruction manual on how to adjust color, ...
Hi, click on the Start Button, in the Start Search Window; Type: power, in the next window; in the (left) Tasks area, click to open "Adjust the display brightness."
Craig, Sorry to tell you that this unit will not work for your application. Your vehicles computer controls require a input and ooutput speed sensor signals to determine shift points. Without the input speed sensor signal the computer will assume its failed and go into limpin mode where it locks in 2nd gear and will not shift. This unit has baiscly identical except for yours that you remvoed is fully electronic as the used unit you have is partially electronic and hydro.
Sorry Man,Hope I answered your question
Sincerely
Roger
