Okay, the serial number that you enter at Goodmanmfg.com should be 10 digits long. I sometimes have trouble enterring unit for warranty purposes and because I have mild case of dylexia, I sometimes transpose numbers. You may check the order of the 10 digits again when you write them down and again when you enter them into the website. If someone else has inadvertantly enterred your serial number for another unit because they enterred the wrong number, you will not be able to register your unit on line. You will need to the call the warranty desk of Goodman and register it with them over the phone. They will probably send a message to whoever the number is currently registered so the correct number can be updated on their unit. If for nothing else the people I have talked to at Goodman warranty are really nice people and they will help you get this straightened out. You can always get your contractor to register the unit if he has not already done it. I do it for my clients all the time and I try to remind them I have it registered. You might call them and see if they did it with out your knowledge.
Hope this helps
Unfortunately, no. Each manufacturer has their own coding system for serial numbers. Which to them reveals many things about the unit, regardless of the Model Number. Only Goodman can tell you that. If you live in the USA contact Goodman Residential Customer Support @ 1-877-254-4729.
I really hope this helps you. Please let me know and thanks for choosing FixYa.
I had the same problem. I took a chance and bought a Chunghop K-1010E universal a/c remote. After trying numerous codes, I found a compatible code - 898 - that controls all functions. It was $13 including shipping on eBay.
On a Goodman the inside unit has a fan relay which is relay time delay sequencer. You have to have the right one or they do not work. They are located on the inside unit just as you take off the door close to the front. Now if you havea fan board that is different. You will need a service tech to replace that because you cant get anyone to sell you the board. The sequencer is easy to change but you need to get the right one. Go by the Model number. Go to parts house that sells A/C parts. Tell then you have a Goodman and need fan relay . You single pole double throw fan relay. You can call a service tech and ask for free estimate up front. Rus
