Have black screen and will not boot up
It is located on the motherboard.
The motherboard is difficult to reach on any laptop... here are some guidelines for your 5560:
http://www.insidemylaptop.com/disassemble-acer-aspire-5560-series-laptop/
http://www.insidemylaptop.com/images/Acer-Aspire-5560/laptop-disassembly-23.jpg
SOURCE: where can i find CMOS battery of my laptop ACER travelmate
You will have to turn it upside down and start removing compartments untill you find it. (As you did not give me the model of the computer I can't tell you exactly where it is)
The CMOS battery is located on the motherboard and it looks like a large watch battery.
Details on changing it is here: http://www.smartcomputing.com/editorial/article.asp?article=articles/2004/w1510/32w10/32w10.asp&articleid=24031
Have a great Day!
SOURCE: CMOS Battery location/image for Acer Aspire 5610
The CMOS battery is located on the motherboard. You would almost have to take the complete thing apart before you find it. You would be better off downloading password recovery software like OphCrack. It's free as an .iso file so you would just burn it to a disc and it will find the password for you.
Pls rate this solution.
SOURCE: my acer 6930 boot up but screen stays black with
Try this fix...
When you get the system started and it finds your startup disk you will see a screen that says Press any Key to boot from CD. I normally use the space bar as my any key and then you should see a blue screen that says Windows setup in the left hand corner. Wait until you see the welcome to setup screen and then click the "R" key to get to the Recovery Console How long it takes to get to each of these depends on the speed of your system, but I will tell you that it will take a few minutes to finally get to the Console.
Once you are at the Recovery Console you will be given at least one choice of Windows installations. Normally the choice you want is the number 1 choice. Click the number 1 key at the "top" of the keyboard and click enter.
You will be given a message asking for the administrator password. Unless someone or something has messed with your computer there is no password so you just click the enter key.
This will bring you to a prompt that says:
C:\WINDOWS>
Type: cd \ and then click enter
( Note: between "cd" and "\" there should be a "blank space" otherwise the command won't work. If you find that a command hasn't worked make sure you typed it correctly. These are similar to old DOS commands where spaces had to go between each command so DOS knew where one command stopped and another started.)
You are now at the ROOT of the drive where it all begins. The Prompt should now say C:\>
Now type: CHKDSK /R and click enter.
The chkdsk / r command also includes the P command and will also look for lost recoverable information in bad sectors.
Now after the chkdsk has run type: FIXBOOT then click enter.
It may prompt you with a warning but continue through it and once fixboot has finished type: EXIT and click enter.
Your system should reboot and when it does click the F8 button to get a windows start menu. Use the up or down arrow to highlight the LAST KNOWN GOOD CONFIGURATION and click enter. If it was a simple drive error this should have fixed it.
SOURCE: need to change cmos battery
Hi
I am giving you another model for dis assembling and from this way you can change your cmos battery.
http://www.insidemylaptop.com/take-apart-acer-aspire-5520-laptop/
Remove the CMOS battery from socket and change .
For Purchase
http://www.buy.com/sr/searchresults.aspx?loc=33409&sid=48
http://www.bizrate.com/travelmate-cmos-battery/?sc=1
http://www.buy.com/retail/searchresults.asp?qu=cmos+battery+for+Acer+TravelMate+4150LCi+PC+Notebook&queryType=home&storeResults=0&cb=338259E-02
Hope it will help you.
SOURCE: The battery charge light shows
Hi cqs2000.
Do the following: "To "Remove the CMOS battery form the computer!" Shut-down the computer. "Unplug the computer from the {Wall Out-let}. Remove the Lithium battery from the "Notebook." There is a compartment (underneath) the "Notebook that 'store' the CMOS battery." "You will need a {very small Phillips screwdriver}. Remove the CMOS battery for: [30 minutes]. !Important: If you have to do it again? Remove the CMOS battery for a {'longer amount of time'}. Replace the "CMOS battery." Next, "Only plug-in the "Power Adapter" into the computer. "Do not - replace the "Lithium battery!" Once you have completed these 'task'. "Restart the computer." "Press the [F2] key, to 'enter' the CMOS / BIOS Setup!" Next, 'reset' (all) "Values to the Default Settings." "Press the [F10] key to 'Save' the changes!" !Important: "Take a 'moment to rate the help', so I can get 'credit' for the work. Thank you!" - paul7of9
