Cars & Trucks Logo
E
Ed Fiondella Posted on Sep 04, 2017
Hi we have spooky town Bump in the night one of the lamp post won't light any more. The lamp broke off the post, is there a replacement part for it? Thank you!
No dash, radio or door activated interior lights. Checked fuses already
Dash lights (Gone?) - FSB Forums - FullSizeBronco.com
www.fullsizebronco.com/forum/21.../198643-dash-lights-gone.html
Sep 7, 2011 - Fully rotating the shaft counterclockwise past a notch activates theinterior lights within the vehicles. ... No aftermarket stereo, the dash lights stopped working, and my taillights ... 8 15 Courtesy/Dome/Cargo Lamps, Electric Outside Mirrors, ... 12 20 C.B. Power Door Locks, Electronic Shift Motor 4WD, Power ...
Radio died, remote system not working, door locks will not work ...
www.topix.com > Chrysler Sebring
Aug 13, 2008 - So what all is not working at this time is: Door locks (with remote it only ... My lights on the dash dim some times and if I hit a bump the radio goes off, ... All the fuses are good, but still no power to the radio, interior lights, push ...
2009 Chrysler Town and Country No Dash instrument cluster lights ...
forum.chryslerminivan.net/.../55281-2009-Chrysler-Town-and-Country-...
Jan 13, 2014 - 10 posts - ‎5 authors
Air or heat won't come on unless you hit a bump in the road what part do i need to get?
see the diagram:
you must test wires loose, broke or burn, switch , fuse, connector, or blower motor, block resistor test or replace.
Car has been jumping while im going down the road like it is a bumpy road but its not for about 3 weeks. Belt broke on the car about a week ago replaced it. Driving on a gravel road yesterday the car kept...
Coolant on the spark plugs is a classic indication of a failed cylinder head gasket. No point in doing any further analysis 'till you get that squared away. When you replace the head gaskets, it's always advisable to have the heads checked for cracks and warpage.
1helpful
Need the fuse number for the tail lights of the 1998 lincoln town car
Check fuse 15 in the inside fuse block.
This is the only one I can find. Another way is to use a circuit tester lamp with the key on and check each side of each fuse. If the tester lights on one side but not the other then replace that fuse.
Thanks
Jason
3helpful
2answers
95 town car won't start
When the 1995 Towncar turns over but won't start or there is no spark you need to look to see if the O/D light is on once you turn the key on. If that light is on the Power control module has rec'd a code from the transmission that there is a O/D fault and the car won't start until that light is off. If you unhook your battery, red post first and neg next and wait at least 10 mins. and reattach the posts neg first and then the red post next the computer will reset and the light will turn off and the car will usually start. If not repeat the procedure. This is an O/D button or O/D switch problem when the light is on.
Tail lights stopped working (keeps blowing fuse)
you could either have a front marker/signal lamp w/lamp grounded and causing this,remember...when tail lights are on so are your frt parking/marker lights on also..... other than that you could have a feed wire worn thru and grounding out to the frame
2005 town & country reading light
I have the same vehicle. when the sun comes up I will go out and look my self and get back. It should let me post a follow up.
Unable to see dash lamps during day night is fine
check your fuses under the dash board check your number 1,8 fuses if there good it'll be your intrument light behind the dash board
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
