Washing Machines Logo
Posted on Nov 22, 2007
Unlock the control panel to a kenmore elite front loader
How to unlock the the control button on a kenore elite front loader. machine wont start.
  • 6 more comments
  • Anonymous Nov 30, 2007
    the control panel is locked and the machine will not work at all
  • Anonymous Dec 13, 2007
    My control panel is locked also and it was giving me error codes as well. I have unplugged it trying to reset but no luck. I will never buy another Sears product after these high dollar machines.
  • Anonymous Dec 22, 2007
    bad codes
  • jimgr Jan 03, 2008
    Yes, digital controls seem not to be working, machine is locked, clothes are rotting, Sears won't be here for a week.
  • Anonymous May 14, 2008
    I finally got it unlocked, pulled out the wet clothes, and now have a lot of standing water. Sears won't be here for five days. This is the SECOND time the control panel has gone out in seven months. Thank goodness I have the warranty......but this is crazy.
    BK
  • Anonymous Jan 03, 2009
    The control locked light is on. No clothes are in the machine. How do I unlock it?
  • Anonymous Mar 23, 2014
    Time light is on but no buttons work
    The control lock is on , how do I unlock it?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2336
Points
36
To unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
3512
Points
17
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about 1/4 inch or until a click is heard.
6. The door may now be opened.
1helpful
I have a kenmore elite smartwash and the machine says contols locked, is there any way to reset that?
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
tip
Kenmore Elite & Whirlpool Duet Washer and Dryer Control Panel Locked
Hopefully, this simple advice will save you an expensive service call.
Elite 45986 Front Load Washer: HI My lchild lock was activated on my kenmore elit...
1helpful
Kenmore elite washer- won't start - control on front says controls locked. I tried unplugging it but still won't start.
Whirlpool duet red light keeps blinking and wont start. it is not locked.I tried unplugging it and nothing works.
Machine controls are locked out and it will nto start up
My kenmore elite he4 dryer wont start
kenore elite oasis dryer won't start, when start button is held down it flashes F, book says call service center
Wont start key symol appears
Kenmore front loader Model 48102 will not start
Whirlpool Duet Ghw9150pw1 would not start
Alexander
vince
