SOURCE: cuisinart grind and brew coffee maker
here is the link to the manual; http://www.cuisinart.com/share/man/34_man.pdf ask again if you still haven't figured it out :)
SOURCE: Water leaking from the base of the unit.
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
SOURCE: Brand new Mr coffee PSTX
If you look where the reservior fits into the base, specifically where the water goes in, there is a rubber seal. It's held in by a circulary plastic piece and 3 screws. I took it apart there to see if something was amiss and decided after looking at it some that they had put the seal in upside down. So I put it back together with the lip of the seal facing up instead of down and I have not had a single drop of water leak from the reservior again. Now if I can get the thermos pot that came with it to stop leaking every time I pour a cup I will be a happy camper.
